Quick Newbe Question
   / Quick Newbe Question #1
Barryh
Veteran Member
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
One quick question for you guys. I know I brought this up briefly in my first post, but wanted to ask again. My Robin 18 runs strong, but I notice at certain rpm ranges no matter how smooth I throttle up or down it will vibrate excessively in between throttle postions.
Not in all ranges just in between points going low to high. It will also smooth out at certain positions of throttle. Same under load. Does anyone else notice this with there engines, before I look into it further. Is it something I should be concerned about? Is this just during break in. /forums/images/graemlins/ooo.gif Thanks just want to compare notes here.
   / Quick Newbe Question #2
Had the same issue with my PT-180's engine but went away after awhile. Now have about 100 hours on the engine with no problems related with that issue
Thanks Alan, that's what I wanted to hear... /forums/images/graemlins/cool.gif
   / Quick Newbe Question #4
I would give everything in the engine compartment a thorough check for loose bolts. While this may be no more than a new unit settling in, it could also be an early sign that something is loose or making contact with something it shouldn't. Sometimes a twisted hydraulic hose can be putting something in a bind.
Just a thought.
Sounds like good advice, I have already checked and tightend a few bolts was planning on going over it again will include hoses this time. Gas line / tank looks clear may change out the gas filter anyway. Thanks for your help. /forums/images/graemlins/wink.gif
   / Quick Newbe Question #6
<font color="blue"> I would give everything in the engine compartment a thorough check for loose bolts. </font>
That is good advice. I like to check everything in my engine compartment for tightness about every 2-3 months or 25 hours of operation just to be sure. It helps to do it after a cleaning of the engine compartment. Amazing what a little dirt or grass can hide.
You betcha,
Think they could have made the compartment any smaller?!
/forums/images/graemlins/laugh.gif
   / Quick Newbe Question #8
Barry, already notified PT that the engine compartment was too big> Ha Ha. Heck had to remove the block, so i could change the oil filter. Luv the PT but some maintenace issues need to corrected. Hey thats the issue with all products
Very true about most products.
I must admit one of the big draws for me was that it was made by good ol American craftsman, That said I must admit my seat was welded on a little crooked, and the steering has way to much play. Sure it is just where the pin goes through the shaft have not taken if off yet.
On the other hand the little machine is built like a tank, and I couldn't even get anything close in price with the capabilities of the PT. So all in all, I am thrilled with my purchase. /forums/images/graemlins/cool.gif
Speaking of built like a tank... now if I could just quit hitting my head on the ROP"S when I get in. /forums/images/graemlins/confused.gif
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A45676)
2016 INTERNATIONAL...
4'x8' Quick Attach Safety Basket (A47307)
4'x8' Quick Attach...
53 STEP DECK  MIXER TRAILER (A45046)
53 STEP DECK...
Beverage Trailer (A46443)
Beverage Trailer...
2004 FORD F-250 SUPER DUTY (A47001)
2004 FORD F-250...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A45336)
2020 Ram 1500 4x4...
