Quick Question: 3 blades or 4 for an impeller?
   / Quick Question: 3 blades or 4 for an impeller? #1
SensibleNick
Ystad, Sweden
Foton FT254
Hi fellas. Long time no see :)
I have a cheap (and terribly made) Snowblower for my 25Hp Foton tractor. The impeller and impeller housing appear to have been made by a blind guy using a piece of elastic as a measuring tool - a 1" pebble can sit in the impeller housing and not get hit... in some places... in others a ス" pebble will get picked up. :(
Anyway.. After a year or two of picking up stones and shearing it's fair load of shear pins, the impeller is rather tired. I have a choice. Rebuild the impeller with rubber tips, or build a new one (I have endless stainless steel and a waterjet cutter at my disposal) ... my only question is this:
I've heard in the past on this forum that a 4-blade impeller is better than a 3-blade.... WHY is this the case? And is it worth spending four times the time to make a new 4-blader than just re-furbishing the 3-blader?
All views welcome :D
All the best from a misty and dull Sweden! :eek:
   / Quick Question: 3 blades or 4 for an impeller? #2
Each blade on the impeller is like a little shovel. Those little shovels are the things that throw the snow up the chute. The more shovels the better... Some have five ... Since you are building a new impeller you are limited in diameter and depth of the shovels.. all you can do is add one or two more. A four blade would probably be fairly easy to square up while you were welding, five a little harder to get laid out right, but doable... Worth a try... :)
As to whether it is worth it, depends on how good the rest of the unit is. Could be like putting lipstick on a pig. [ :) ] It would make it more efficient, but that's not a call someone can make for you. Some stainless is a little softer than steel, and that could be a problem too... Good luck, Jerry....
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
