Quick Question: 3 blades or 4 for an impeller?
   / Quick Question: 3 blades or 4 for an impeller? #1
SensibleNick
Ystad, Sweden
Foton FT254
Hi fellas. Long time no see :)
I have a cheap (and terribly made) Snowblower for my 25Hp Foton tractor. The impeller and impeller housing appear to have been made by a blind guy using a piece of elastic as a measuring tool - a 1" pebble can sit in the impeller housing and not get hit... in some places... in others a ス" pebble will get picked up. :(
Anyway.. After a year or two of picking up stones and shearing it's fair load of shear pins, the impeller is rather tired. I have a choice. Rebuild the impeller with rubber tips, or build a new one (I have endless stainless steel and a waterjet cutter at my disposal) ... my only question is this:
I've heard in the past on this forum that a 4-blade impeller is better than a 3-blade.... WHY is this the case? And is it worth spending four times the time to make a new 4-blader than just re-furbishing the 3-blader?
All views welcome :D
All the best from a misty and dull Sweden! :eek:
   / Quick Question: 3 blades or 4 for an impeller? #2
Each blade on the impeller is like a little shovel. Those little shovels are the things that throw the snow up the chute. The more shovels the better... Some have five ... Since you are building a new impeller you are limited in diameter and depth of the shovels.. all you can do is add one or two more. A four blade would probably be fairly easy to square up while you were welding, five a little harder to get laid out right, but doable... Worth a try... :)
As to whether it is worth it, depends on how good the rest of the unit is. Could be like putting lipstick on a pig. [ :) ] It would make it more efficient, but that's not a call someone can make for you. Some stainless is a little softer than steel, and that could be a problem too... Good luck, Jerry....
2016 BOBCAT E45 EXCAVATOR (A52706)
2016 BOBCAT E45...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
