Buying Advice R-4 Tires or Ag Tires on Kubota L-3800HST
   / R-4 Tires or Ag Tires on Kubota L-3800HST #21
Of course the Ag tires are taller so your tractor is going to be a little less stable.
I think it depends on the tractor, for mine the R1's and R4's have the same diameter. The turf tires are signficantly shorter and wider though which I think is pretty much the rule for all brands.
I guess a partial solution for brush hogging saplings with R1's is to cut a bit higher, so the stubble is less stiff and can deflect or break before sticking into the tire.
   / R-4 Tires or Ag Tires on Kubota L-3800HST #22
I went with the R4's more of an all around tire.
   / R-4 Tires or Ag Tires on Kubota L-3800HST #23
dontn, I've been going through a similar tire study before getting tractor in hand. Got many good comments in thread "traditional ag vs. industrial tread" (Owning/operating), plus some interesting thumbnails.
Here is something interesting, posted there by platinum member RFB:
" These are the R1 pattern with R4 sidewalls; Michellin XM27's
25 mph 20 mph 05 mph PSI
1,710 lbs 1,830 lbs 2,500 lbs 14 psi
1,940 lbs 2,070 lbs 2,790 lbs 17 psi
2,160 lbs 2,330 lbs 3,080 lbs 20 psi
2,390 lbs 2,570 lbs 3,370 lbs 23 psi
2,620 lbs 2,810 lbs 3,660 lbs 26 psi
2,850 lbs 3,050 lbs 3,950 lbs 29 psi
3,080 lbs 3,310 lbs 4,230 lbs 32 psi
3,310 lbs 3,550 lbs 4,530 lbs 35 psi "
For my purposes, I'm going with the R1. I know, at times, it's gonna farkle up the lawn/surface, but I'll have to learn to live with it. I need all the traction I can get when it gets muddy.
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 FORD F-150 (A52472)
2014 FORD F-150...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
