R-4's: new vs old style
   / R-4's: new vs old style #11
My 1025 has the old style. Slide sideways A LOT worse than the turfs did on the 4010. The R4s (on front) appear to be a lot tougher though. No issues yet at a little over 1 year. Never had any problems with the rear turfs on the 4010.
From the design of the new R4s, I'd say they'd slide sideways more readily than the old style. I get really uncomfortable when I get in a tight spot on a slope going sideways with the 1025, afraid it'll slide sideways.
Ralph
   / R-4's: new vs old style #12
Wow, they sure look closer to R1's than R4's to me. Like Gary said, they look to be more aggressive in loose material.
   / R-4's: new vs old style #13
Just curious if anyone has noticed any difference in the 2 styles of R-4 tires. Better traction? Are the new ones as tough as the old ones? Why the switch?
Is JD the only ones using these? I haven't really looked to see what the other tractors are using.
I guess new vs. old is relative as my 2006 3720 Cut has the "new" design and I am sure JD CUTs have been using the same manufacturer since at least 2000. How old is the bottom picture and are they OEM tires?
Can't comment on traction as I have nothing to compare mine with. Never have slipped sideways but I have never operated on wet turf.
   / R-4's: new vs old style #14
I think they are like a mix between a r1 and r4 , more flex than a r4 6ply and better clean out like a r1 . a little too tight to run chains ,that's why I went with the older style , I don't mind running chained up in the winter .
I guess new vs. old is relative as my 2006 3720 Cut has the "new" design and I am sure JD CUTs have been using the same manufacturer since at least 2000. How old is the bottom picture and are they OEM tires? Can't comment on traction as I have nothing to compare mine with. Never have slipped sideways but I have never operated on wet turf.
If I remember right the "new" tire pic is off a 2014 3033R and the "old" tire pic is off a 2003 4310. I found the pics on tractorhouse.
My 2004 4310 has the old style tread. I didn't think that they started putting out the new tires until around 2012 or so. I have only been looking at 3320's mostly though. Interesting that your bigger, older tractor has the new style.
Also interesting is a pic I found of a a slightly different R-4 on a 2011 3320. The tread is the same as the old style but it has the little runners (I have no idea what they're called) in between the tread. image-780982616.jpg
   / R-4's: new vs old style #16
That's what I have on my 08 3120 , the other style r4 (new style) was available when I bought in 09
   / R-4's: new vs old style #17
My 4310 is a 2004 and has the old style R-4's
   / R-4's: new vs old style #18
Also interesting is a pic I found of a a slightly different R-4 on a 2011 3320. The tread is the same as the old style but it has the little runners (I have no idea what they're called) in between the tread. View attachment 398463
Sometimes when I read my comments I realize I had nothing to add to the conversation. Truth is I bought my 3720 with 600 hours on it and it is entirely possible the tires had been changed. I can say they have worked great for rotary cutting and FEL work on a variety of dirt conditions for the last 250 hours but my gut feeling if I wanted to run a plow I would need R1 tires. Again, nothing to add, but have a great weekend!
   / R-4's: new vs old style #19
Looks like I've got the old style on my Kubota L4330:
I've never seen the new kind on anything but JD. Although my search has been limited to a few minutes on tractorhouse.
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
