HangtownMatt
Can a person tell, just by looking, if the wheels have been adjusted to the widest postition? Or, do you need to remove the wheels? Tires from rims?
HangtownMatt
HangtownMatt
HangtownMatt said:Can a person tell, just by looking, if the wheels have been adjusted to the widest postition? Or, do you need to remove the wheels? Tires from rims?
HangtownMatt
weesa20 said:I think another consideration needs to include available traction. Many accidents happen because tires begin to spin and then the tractor begins to slide either backwards (downhill) or downhill sideways in an unexpected direction. Either way, once the tire or tires regain traction, it is a precarious position to be in. Imagine a tractor with turf tires traversing a sidehill and then sliding 10 feet down the hill and then regaining traction. The momentum can tip the tractor. Now imagine that the tractor had R1s that never lost traction...there are many variables that need to be considered when determining tractor safety.
Doc_Bob said:YEs, by looking at the owners manual. This is true with my NH TN70A
Bob
patrick_g said:Kubota forbids liquid fill in rear tires of my Grand L-4610HSTC, hence my use of wheel weights, which are approved.
Pat
patrick_g said:john_bud, I was with you until you said, "To tip the tractor over, you have to move the up-hill tire up higher than the CG of the tractor ." I do not believe this is true.
Ignoring the differences between static and dynamic stability for now lets start with the simple case, static. If the CG of the tractor-implement combination (carried implements not towed) is moved such that it is outside of the outermost support then the tractor will at least fall onto its side if not roll over. This is irrespective of the relationship of the high side wheel to the CG.
Example: Fill the FEL bucket full of heavy material and raise it as high as it will go. This raises the CG quite a bit. A small sideways tilt such as driving at right angles to the slope of the land can place the altered CG beyond the support and initiate an accident where the tractor lays down on its side. This greatly reduced angle of roll requirement prior to passing the point where the tractor will remain upright is one of the good reasons to be extremenly cautious about raising a heavy load very high while on a slope or when in motion.
Dynamic case: If you are in motion then centrifugal force is at work on your CG tending to roll you over to the outside of a curved path you may steer. The angle of tilt required to initiate a roll over is reduced the more G's you pull by turning. With a heavy load carried high you can easily roll over on level ground. Of course uneven ground with any lump in it can serve to launch you into a roll over event like special effects in a movie's chase scene.
Partially filled tires, up to about 50%, defininitely help lower the CG but at times the unbaffled free surface liquid fill might contribute a little to instability. I have cast iron wheel weights bolted to the rims instead of liquid fill and it is way better than not having any weight on the wheels, just not as extreme as filled tires but not so much bother or source of corrosion or...
Pat
patrick_g said:I have had my L-4610 in all 2 wheel AND 3 wheel combinations there are and most of them more than once. Sometimes the pucker factor was intense. I have 5 years and a bit over 700 hours on the clock with this Kubota and find that I have learned some things to not do again on purpose if they can be avoided.
Pat
