R4 Tire PSI
   / R4 Tire PSI #11
kioti ck 30,rears15-19.5,,ind, 6ply,18 -19 psi loaded with methinal,,,,front[without a loader],25x8.50-14,ind.,6ply,28-30 psi,you need more if you got a loader on it...
Book says,30 rear,50 front,titan tire[after communicating with them] agrees with my settings,they just gotta go with the same safety stuff,watch your lawyer stuff that my copenhagen can says in owners manuals...
So,you can run about 18-19 lbs in rear,no matter what,,front tires pressure depends on loader,and than,loader use..
If I had a loader,would be running about 50 psi in front..You could probably run 10 psi in rear and 20 in front,if you didn't have a loader or spin your tires a lot under heavy load.
   / R4 Tire PSI
OK....I aired the front ones down to 34 psi and the rear ones to 18 psi.
The front ones had entirely too much, way over the max. rating on the sidewall, the rear had 34 psi which was the max. rating on the sidewall.
Major improvement :thumbsup:
   / R4 Tire PSI #13
Which R4's do you have? The larger (4ply) aren't rated for the same pressure as the smaller (6ply) tires.
Rob
   / R4 Tire PSI #14
They are thick walled, but the aspect ratio (sidewall height to tread width) is very different between an automobile tire and the front tire on a compact tractor...it really doesn't take much to roll them little suckers off the bead. Unfortunately, I speak from experience.
I was only talking about the rear tires. I run my fronts at 30. I agree, thos could lose a bead pretty easily.
With the 3720 cab I find it too bouncy and tippy with anything over 15 in the rear. My open station 3720 was not so sensitive.....
   / R4 Tire PSI #15
The dealer told me to run my rimguard loaded r4 rears at 14. Doesn't make sense to me that it needs to be lower but anyway that's what I'm doing. Seems to work ok traction wise. My fronts are at 30psi for loader work and not loaded. The thing basically rides over rough terrain like one of those big wheeled bicycles from the early 1900's.
   / R4 Tire PSI
Rob
I have the smaller R4's. (Height was an issue for me with the cab. Wanted to be able to get it into my storage building.)
   / R4 Tire PSI #17
I ordered my 3320 with the large tires and found they were a little shy of my 8' foot door so i asked my dealer to switch them to the smaller ones. He told me it might be tough once it's ordered but he'd try. I won't know till it gets here what I have but either way I think I'll run them in the wide position.
Rob
   / R4 Tire PSI #18
...either way I think I'll run them in the wide position.
Rob
Good idea...and if you get those tires filled, let the dealer's staff swap them around for that wider stance. More stable and will be easier to rig the tire chains (which you'll probably want since you're in the Catskills).
   / R4 Tire PSI #19
I went without chains on my last tractor just running on 4WD until I slid off the driveway after a big storm last winter. The snow just iced up, we hadn't seen anything like it in years but you're right Roy, I'll get chains for the new guy as it took me 3 hours to dig out by hand!
Rob
   / R4 Tire PSI
Absolutely get them turned out! I did and am glad of it!
2014 John Deere 244J (A47477)
2014 John Deere...
11' CONTAINER (A54757)
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
Electric Mobility Scooter (A51694)
Electric Mobility...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
