TnWV
Platinum Member
- Joined
- Apr 29, 2008
- Messages
- 588
- Location
- Liberty,WV - Putnam Co.
- Tractor
- 2003 Zetor 4341 w/FEL, 1970 MF 150, 2012 JD X530
Hey guys, I building a new house that has a full basement (I plan to start a full build thread ASAP). I want to heat the basement using radiant floor heat and have a question about PEX size. The basement is 2100 square feet, so I am thinking 7 loops of 300' makes sense. I can buy 300' rolls of oxygen barrier 1/2" PEX readily. It seems many use 1/2" inch and are happy with it, but I have had a couple of recommendations that I use 5/8" PEX. Problem is, I can only seem to find 5/8" PEX in 250', 500', and 1000' rolls, which makes the layout harder to not waste part of each roll. The basement will not be finished to the same extent as the main living floor, but will be finished enough to be usable for various activities, such as exercise equipment, dog wash room for my wifes dogs, etc. My question is, is 1/2" PEX sufficient? If so, that makes things much easier as far as purchasing the PEX. That said, if 5/8" is the correct size, I will deal with the size rolls I can get. Based on reading other threads here, I plan to staple the PEX to the rigid foam insulation, so it will be at the bottom of the concrete.
Thanks for any insight!
Tony
Tony
