Radiator Pressure
   / Radiator Pressure #1
buppy69
Platinum Member
Western NC
Hinomoto E2804, Hinomoto N239,
What would cause pressure in the radiator to build up and blow into the overflow bottle and even out of it? I've replaced the cap with a 16lb one. The temperature of the water never gets so hot that you can't put your hand in the bottle.
Eugene
   / Radiator Pressure #3
Start engine cold with radiator cap off and check inside radiator for bubbles, a sign of a glown head gasket, or crack somewhere, allowing combustion pressure into cooling system.
   / Radiator Pressure
Thanks, I will check for head gasket but this thing runs like a charm. Wouldn't it run rough if it was leaking compression?
Eugene
   / Radiator Pressure
I just checked. No bubbles. The coolant doesn't appear to be circulating though. (This has a water pump).
Eugene
   / Radiator Pressure #6
'Wouldn't it run rough if it was leaking compression?"
Maybe, at this point all you know is that something is building more pressure than the cap can hold. Could be the cap is not seating/sealing properly. Sometimes the only way to detect a blown head gasket is wetness seeping from under the head, or just loss of coolant.
   / Radiator Pressure
I just let the tractor run until the guage got up to the same temperature where it was building up today, and with the cap off it didn't overflow.
Eugene
   / Radiator Pressure #8
What model Yanmar is this? 16# seems high.
   / Radiator Pressure #9
If you can't see the water moving I would take a look at the water pump. Take the top hose loose from the radiator and see if the water pump is working. The impellar could be worn out or loose. You should have a 13# cap.
Danny
   / Radiator Pressure
Will do. But if the water pump wasn't working, would't it run hot?
Eugene
Flatbed (A51691)
Flatbed (A51691)
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
