Radiator screen
   / Radiator screen #11
That is the nice part about testing with a hose and water it costs nothing and you really can see from the spray pattern before and after the restriction.
   / Radiator screen
The blue filter has been trashed, based on recommendations from murphy, so I made the plywood frame with aluminum window screen stapled to it. Should be fine and have plenty of airflow without doing the garden hose test. I have a temp light and gauge anyway.
   / Radiator screen #13
Alvanko, I finally did that too. Got some 1/4" plywood cut down at the store and made one for each tractor. Left about 1" all the way around to staple the screen to. Very easy job.
I like your "design" better then mine. I may have to make a new one this summer.
   / Radiator screen #14
If you can find a good metal screen that is the very best, most places do not have metal screens anymore.
   / Radiator screen
Lowes has it. It is aluminum window screen, easy to cut with a plain pair of scissors. If you have a good hardware store that still makes replacement window screens you could probably get only what you need. I bought a small piece of 1/4" plywood at Lowes and they cut it to my specs with their panel cutter. Total cost on the plywood was less than $5 bucks.
   / Radiator screen #16
a good metal screen in front of every radiator is a great idea to keep the bugs out of the coolers and radiators, that works, In this area metal screen is getting hard to find and the plastic stuff is nearly waterproof.
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2013 UTILITY VS2DX DRY VAN TRAILER (A54607)
2013 UTILITY VS2DX...
1995 Rinker Captiva 190 (A55218)
1995 Rinker...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
