Gregster613
Platinum Member
- Joined
- Apr 19, 2009
- Messages
- 907
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
Hi guys, I thought I was done with my current projects but wife had other ideas. Ha! Actually it was good for me as I got more seat time in anyhow! But I was concerned about running my beast if it had problems? So after letting it sit overnight... I open up radiator cap - top off water level {to just below neck} - leave cap off while I start up engine and let it idle until warmed up so I could see if'n I could tell if the thermostat was opening or not. Sure enough it appears to be opening after engine gets warmed up. The water seemed to stay smooth while cold and then sort of "burgled" (can't think of a proper name for it) -- it was like bubbles but not with air? So I believe the thermostat is working correctly.
Bob Rip, Flyerdan, and Boggen had it right I believe. The old cap {may} have been getting hung up - still unsure about that, but am using new cap anyhow - and I believe that I was filling the radiator with too much water. That's because while I watched it "burble" it would expand and drain down the overflow tube. So I left it idle and burble for quite some time to ensure no air in system, watched temp gauge closely also and it stays right in the middle where it should be. After it drained down some and I was fairly confident it wasn't actually overheating I put the cap on and went to dig a few more postholes for some trees we are planting. It seemed to run OK! I did shut it off while mounting the equipment and when not actually digging holes - rather than leave it idle.
Long story short, I believe I was adding too much coolant and I am just going to make it a practice to check the water level - as I do the screen & engine oil every time before I start up the engine. These small tractors seem to be much more heat concious than the farm tractors I was used to running. Of course, on these the radiator is packed in behind the tranny cooler, battery, and in a much more compact frame! Thanks so much for the suggestions and ideas!
I still will try to rig up some sort of recovery system and see if that helps retain water, although I am unsure how I will manage to mount it in the confined space available to work with. Whenever I next get to a Harbor Frieght I'm going to get one of those infrared head guns so I can get an actual idea of the # range I'm running at also. Thanks for helping me put a possible overheat issue to rest! Fare well. Greg
