Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #41
Here's an idea, did your "friend" push the Tow/Haul button which disables the MDS? I assume no offset still think it's MDS. There was a TSB for torque converter programming which fixed the hesitation problem.
Anyways, back to fuel mileage comparisons and not "My friends broken non-Ford" like every other thread in this forum...
I don't know if he tried the tow haul mode or not. He used to be a big Jeep enthusiast until this happened. I looked on a Jeep forum a months ago and saw people were still having the problem. His inlaws have on that also does it.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #42
I've owned 4 late model hemis. I've never had a problem with the Mds. On the truck I owned, at times it would have a problem holding MDS on hills or strong head winds. MDS works better on cars in my opinion, but that's aerodynamics.
I've done a lot of Internet reading on late model hemis, what ever that's worth. The only problem I've really read about is timing chain failures. It appears to be most common on the Challengers and only 2010 and 2009 model years. It seems when they switched to variable valve timing, the chains got smaller due to space limitations. There is speculation MDS contributes to the problem but no one knows. It appears the gearing and programming is unique on the Challengers and the failure occurs at 70 mph. It seems the failure is rare but Chrysler isn't talking.
Consumers report came out with an article recently about the ecoboost. Not just the trucks but all the Ecoboost engines. They were basically saying what Dmace says. You can get a regular engine that does just as well. I don't put a lot of stock in what they say, we would all be driving Accords or Camarys if we listened to them. Yawn.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #43
Yeah I remember it: F-150 Eco Boost Towing Vs Nissan Titan
I guess I should be more descriptive for those who think little u-haul box trailers and boats are real towing. I'm talking large enclosed trailers and campers, the stuff probably 75% of truck buyers tow. A 30ft 8k enclosed trailer/camper is a lot different than some small cargo trailer or a pop-up.
Look on some RV forums, those are the guys seeing single digit mpg's and drivetrain issues (shudder, limp mide, etc...).
RV.Net Open Roads Forum: Travel Trailers: EcoBoost towing gas mileage?
Good luck pulling an 8k lb trailer with a Ram. They have neutered the payload even more on the 2013's since they changed the suspensions. Since you linked that rv site, you've no doubt seen threads on there like this RV.Net Open Roads Forum: Can this be right? Laramie longhorn crew 4x4 1500 where they are finding the Ram is overloaded with passengers alone, and have no 'available payload' left for anything in the bed let alone a trailer. It's a shame Fiat turned the 1500 Ram into an SUV that looks like a truck, forcing real truck owners to buy a 2500 for truck capabilities.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #44
Good luck pulling an 8k lb trailer with a Ram. It's a shame Fiat turned the 1500 Ram into an SUV that looks like a truck, forcing real truck owners to buy a 2500 for truck capabilities.
Or just get a brand with some payload. My last F150 had 7,700# GVWR and weighed about 5,700# leaving me plenty of payload of about a ton.
My current Nissan Titan has 7,200# GVWR and weighs 5,840# leaving about 1,400#. The early Titans suffered the same problem with a 6,500#ish GVWR.
Chris
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #45
Yes this article was discussed heavily on a f150forum.com. They compared the ecoboost to the 5.O liter with only one criteria, fuel economy. My thought is apples to oranges with the 5.0. to ecoboost. Ecoboost makes more torque than the 6.2 liter it replaces up to about 4000 rpms yet uses much less fuel for normal driving. Even in their comparison, it got the same mileage as the 5.0 and they didn't care about the improved performance.
Consumer Reports finds small turbo engines don't deliver on fuel economy claims
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #46
Chris
Here is the door sticker in my ecoboost and I don't even have the heavy payload option. That would add another 500 lbs. I would have ordered that package but didn't want the 6.5 foot bed. There have been a couple times I have been a little over the 1835 lb payload.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #47
I just threw out the 150,000 miles to prove a point. The lifespan may be greater or less than this. I was mainly conveying that I will be satisfied if it makes it to 150,000 miles.
I agree that there will be plenty of re manufactured options available when the needs arise. I would expect in a few years to be able to go the the local autoparts store and buy one off the shelf.
I threw out 150k for a turbo on the ecoboost because Ford has a memo out saying it has a life cycle is 150k or 10 years.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #48
I guess that my old antique 03 F350 crew dually 4x4 with a dinosaur 7.3 is so outdated...
14.5 mpg running back and forth to work and a solid 10 to 11 pulling as much weight as I want to...
And it's paid for...
To be honest with you, I see no reason to add a truck payment for anything Detroit is making now over what I have got...
Mine, 1996 Dodge, sounds like it should be an antique too! She still gets done whatever is required with pretty nice fuel mileage! Got no complaint on the interior layout either. it's even got a cupholder where it's supposed to be. :thumbsup:
Course some may think it rusted out about 12 years ago or shoulda shed a bunch of transmissions but them things ain't happened yet. :D
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #49
AH, thanks for the clarification. I just pulled my number from the air and luckily it was the same number.
   / Ram HEMI 8 speed 4x4 rated same as Ecoboost 4x4 EPA fuel mileage. #50
Here are the towing specs from Ram directly. Looks like the maximum GVWR is 6800 lbs. You are correct, that doesn't allow for much payload. If you had a foursome and clubs, might have to drive two vehicles.
They are though similar to the 2012 model which is also low with the exception of the tradesman HD model. They dropped that model for 2013.
http://www.ramtrucks.com/en/towing_guide/pdf/2013-RAM.1500.Towing.Specs.pdf
Peterbilt 377 Semi-Truck (A53473)
Peterbilt 377...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
UNUSED FUTURE SSJ430J WALK BESIDE JAW CRUSHER (A51247)
UNUSED FUTURE...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
