jejeosborne
Veteran Member
What good is that self leveling suspension? If it adds significant weight to an already class failing payload what weight will it be leveling? I have never seen a payload that low even in a car.
I'll help.
It's 1300 lbs before you start adding any options. Huh. That seems a little low...
I'll help.
You're comparing it to an F150 Limited? The Limited already has nearly every option included. That's why the payload "starts" so low on it compared to other F150's, because it's a pig when it comes to 'options included'.
This, folks, is the real issue with the Ram EcoDiesel: 2014 Annual Physical: Braking - PickupTrucks.com Special Reports
490 lbs! I'm not big in the 'my numbers are bigger than yours, so my truck is better' game, but this is ridiculous. How are you supposed to tow the 8k lbs if you only have room for < 300 lbs of tongue weight after putting yourself and the hitch in your truck? Granted, it's a fully-loaded version, but still!
