ran in to problem
   / ran in to problem #1
allen6634
hawesville
600 ford
i am rebuilding my 600 tractor steering gear box, i bought new worm gear, bearings and cups, today i started to put this togther , and the steering shaft don't want to fit right,( when i tighten it up the steering locks up) im not sure why , i have put the box completly togther, but i have to leave the top lose.i can't get any end play even with shims.
   / ran in to problem #2
i sent you pm on the 4 areas to mesure / observe. bearings and races profile.. seat deptch.. wormshaft repalcement dimensions.
   / ran in to problem
i know i just posted this before i sent you that pm , and buy the way thank you for replying, i am going to take the box back apart to check all the things you told me.
   / ran in to problem #4
rare.. but I have seen incorrect races, or not seating good.. or wrong profile bearings that had straight cylinders and not the bbls...
good luck
   / ran in to problem
i found my problem today, i took everything and layed it on my bench , i left my wife in the house ( she likes to help ) and i found that the shaft was bent . id like to thank soundguy for his help in this matter , now im just waiting for warmer weather. to put the tractor back togther.
   / ran in to problem #6
good luck with her.
   / ran in to problem #7
I'm sure Sounder gave you good advise, first thing that comes to mind are the bearing cups aren't seated properly.
   / ran in to problem
i found out the steering tube was bent it would put every thing in a bind when i tightened everything down i got the gear box put back on the tractor yesterday it will be ready for the summer in no time. i would like to thank everyone who has offered advice .
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2006 BIG TEX 16 T/A TRASH TRAILER (A53843)
2006 BIG TEX 16...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
