Ratchet chain binders - are they all equal
   / Ratchet chain binders - are they all equal
Where did you get them at and what brand are they if you don't mind sharing
   / Ratchet chain binders - are they all equal #22
They are SCC Quickbinders. I got the 5/16-3/8.Tarpstop® Chain Binders - Ratchet Binders and Lever Binders for Grade70 Chains, Cargo Tie-Down
No real need for larger ones unless you have a very specific application. What many people fail to realize is very few tie down points on trailers are rated over the 6,600 lb WLL you get with 3/8 GR70 chain. To use larger chain or binders is a waste because they are only as strong as the weakest link. My 53' flatbed has what appear to be very heavy duty stake pockets and pipe spools and the rub rail is thick. Way stouter appearing than anything I have ever seen on a gooseneck and these attachment points are only rated for 5,400 WLL.
Thanks Much
The Best for the new year
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2010 Case 580N (A60462)
2010 Case 580N...
2001 International 4000 DT 466E (A60462)
2001 International...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
