Ratchet Rake OR Piranha Tooth Bar?
   / Ratchet Rake OR Piranha Tooth Bar?
Very helpful in addressing my questions. Thank you.
jeff9366
The Kubota L3560 is here. I purchased another Ratchet Rake. Decided I needed the short row of vertical teeth, pointing down on the bottom of the Ratchet Rake, for piling brush after tearing it out.
The L3560 has heavy LA805 FEL and optional L2296 (SSQA) HD Bucket. The Ratchet Rake fit on the L2296 Heavy Duty Round Back Bucket smoothly. I learned from my prior 52" Ratchet Rake, used on a 2,000 pound lighter Kubota B3300SU Tractor/Loader, that the two clevis , which attach through the bottom 'eye' on the RR and provide connection points for the steel cables, will come loose because the pins unscrew. So I found and used bolted and cotter pin secured "safety" clevis, which I bought on eBay. I have never seen "safety" clevis in hardware stores; they may be a marine specialty fitting.
The 68", 88 pound Ratchet Rake, on the 72", 397 pound L2296 HD bucket, attached to LA805 FEL, powered by a L3560, is a powerful combination.
SAFETY CLEVIS SHACKLE LINK:
3 8" Shackle Clevis Safety Pin Peerless 1 Ton WWL | eBay
   / Ratchet Rake OR Piranha Tooth Bar? #23
Congratulations!
You can also substitute the correct size hardened bolt for the shackle pin, amd use a lock nut on the side where your cotter pin is on the safety shackle.
We had a similar issue with shackle often becoming unscrewed on the winch-attachment point of our snow plow, and that wss my eventual solution.
Thomas
The Kubota L3560 is here. I purchased another Ratchet Rake. Decided I needed the short row of vertical teeth, pointing down on the bottom of the Ratchet Rake, for piling up brush piles after tearing tearing it out.
The Ratchet Rake fit on the optional L2296 Heavy Duty Round Back Bucket smoothly. I learned from my prior 52" Ratchet Rake, used on a 2,000 pound lighter Kubota B3300SU Tractor/Loader, that the two clevis , which attach through the bottom 'eye' on the RR and provide connection points for the steel cables, will come loose because the pins unscrew. So I found and used bolted and cotter pin secured "safety" clevis, which I bought on eBay. I have never seen "safety" clevis in stores; they may be a marine specialty fitting.
The 68", 88 pound Ratchet Rake, on the 72", 247 pound L2296 HD bucket, attached to LA805 FEL, powered by a L3560, is a powerful combination.
   / Ratchet Rake OR Piranha Tooth Bar? #24
Jeff366 you sure your about your machine weight?
Dimensions & Tires:
Wheelbase: 71.1 inches [180 cm]
Weight: 3483 to 3880 pounds
Front tire: 7.0-16
Rear tire: 12.4-24
Fairly sure, but not sure, sure, sure.
From Kubota L3560/LA805 Operator's Manuals:
L3560 HST Tractor-- --------------3,649 pounds (presumably with Ag tires)
LA805 Loader----------------------1,279 pounds
L2296 72" Round Back HD Bucket--397 pounds
SUBTOTAL--------------------------5,325 pounds
How much additional weight should I allow for optional, heavier R4 Industrial Tires over standard, lighter Ag Tires?
   / Ratchet Rake OR Piranha Tooth Bar? #26
Guess I'd go with your Kubota Manual over Tractor Data seeing Kubota doesn't do the Nebraska Tractor test.
   / Ratchet Rake OR Piranha Tooth Bar? #27
Great looking tractor Jeff! Now you need a set of QA pallet forks! Makes moving those giant brush a breeze! My favorite tractor attachment by far.
I have the rachet rake too. I'm planning to get a piranha tooth bar as well. According to others above the RR will fit over the PTB.
I like that you have something on the back of the tractor. Theses tractors NEED 3 point counter weight. My front axle bearings need replaced at 730 hours because of lots of loaded use without proper weight balance.
   / Ratchet Rake OR Piranha Tooth Bar? #28
That sounds about right. You have loaded rear tires?
No. I run over residential lawns too often.
With the 1,279 pound loader and 397 pound bucket in front I keep an implement on the back most of the time. Usually a 630 pound Rollover Box Blade, sometimes my 772 pound ETA Cultipacker. The Cultipacker is especially compact.
   / Ratchet Rake OR Piranha Tooth Bar? #30
May need a Turbo like Fred did to move all that weight. What's PTO HP?
AGRICO FERTILIZER SIGN (A58374)
AGRICO FERTILIZER...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
23ft x 22ft Double Garage All Metal Building (New/Unused) (A59225)
23ft x 22ft Double...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
