Raw fuel kioti tractor 22 hp diesel
   / Raw fuel kioti tractor 22 hp diesel #1
frank360
Bronze Member
Lakeland, LA
Mahindra 2615
I have found that i have raw fuel coming out of exhast at high rpm. could this be caused by incorect timing? the fumes burns my eyes.any where from 2400 rpms up to max rpms of 2800
   / Raw fuel kioti tractor 22 hp diesel #2
frank,this could be timing,or a bad injector tip,or incorrect compression.you didn't say how the engine was running overall,if the engine is running ok i would say you have a injector overfueling.a timing problem would probably cause the engine to run rough.
the tractor runs very good.iam going to check compression tomorrow
   / Raw fuel kioti tractor 22 hp diesel #4
If you are going to pull the injectors for a compression check, while you have them out take 'em to a fuel injection specialist shop. Have them check the injectors for spray pattern and pressure settings.
If there isn't one listed in your phone book (under fuel injection) call a heavy duty diesel truck/engine repair shop and see who they recommend.
As stated by dieseldoc, the problem you describe could be a faulty injector(s).
   / Raw fuel kioti tractor 22 hp diesel #5
Frank, how about an update? /forums/images/graemlins/confused.gif Did you discover the cause of the extra fuel? /forums/images/graemlins/smile.gif Or, any discoveries about what isn't causing it? /forums/images/graemlins/tongue.gif
I pulled the head off today and will bring it tomorrow to get it presure tested i will let you know asap what we find.
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
2024 KMC 7406 (A53084)
(30) Galvanized Steel Public Space Fence (A51573)
(30) Galvanized...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
