Raw fuel kioti tractor 22 hp diesel
   / Raw fuel kioti tractor 22 hp diesel #1
frank360
Lakeland, LA
Mahindra 2615
I have found that i have raw fuel coming out of exhast at high rpm. could this be caused by incorect timing? the fumes burns my eyes.any where from 2400 rpms up to max rpms of 2800
   / Raw fuel kioti tractor 22 hp diesel #2
frank,this could be timing,or a bad injector tip,or incorrect compression.you didn't say how the engine was running overall,if the engine is running ok i would say you have a injector overfueling.a timing problem would probably cause the engine to run rough.
the tractor runs very good.iam going to check compression tomorrow
   / Raw fuel kioti tractor 22 hp diesel #4
If you are going to pull the injectors for a compression check, while you have them out take 'em to a fuel injection specialist shop. Have them check the injectors for spray pattern and pressure settings.
If there isn't one listed in your phone book (under fuel injection) call a heavy duty diesel truck/engine repair shop and see who they recommend.
As stated by dieseldoc, the problem you describe could be a faulty injector(s).
   / Raw fuel kioti tractor 22 hp diesel #5
Frank, how about an update? /forums/images/graemlins/confused.gif Did you discover the cause of the extra fuel? /forums/images/graemlins/smile.gif Or, any discoveries about what isn't causing it? /forums/images/graemlins/tongue.gif
I pulled the head off today and will bring it tomorrow to get it presure tested i will let you know asap what we find.
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
4 GOODRICH LT265/70R17 (A53843)
4 GOODRICH...
2007 KUBOTA M9540 TRACTOR (A53843)
2007 KUBOTA M9540...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
2006 DRAGON PRODUCTS 150BBL VACUUM TRAILER (A53843)
2006 DRAGON...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
