OP
SandburRanch
- Joined
- Oct 12, 2010
- Messages
- 1,543
- Tractor
- NHtd75
Today i ground a re-bar electric fence post and it was without a doubt ---steel .
And Home Desperate, Lowers, the Local Lumber yard, etc., frequently have Grade 40 bar, which is suitable for slabs on grade, low stress footings, etc. Grade 30 bar used to be listed in charts but was unobtainable, and if you did find it took up so much of the forms, you couldn’t form it with anything greater than 3/8-inch aggregate.Low end rebar is pretty much junk/mild steel rolled with not much regard for quality....
BUT....
Good quality rebar will have information about its source and composition.
Fiberglass is hard to weld....I’m just wondering is there some reason not to switch to the new, cheaper, stronger ,lighter and rust proof fiberglass rebar ?
