re-sealing some old Kubota B8200 FEL cylinders
   / re-sealing some old Kubota B8200 FEL cylinders #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I agreed to fix the leaks on a friend's old 80s era Kubota B8200.
This tractor is common around here, and the way the cylinder goes together is just about my least favorite. The end cap (gland) uses a springy wire that is captured by a groove inside the lip of the cylinder barrel.
I have done this type before, but I am not an "expert". Probably only rebuilt 25-30 cylinders in my life.
The wire is always stuck in there, so the first thing to do it to free up the gland by pushing it in just a bit.
I use 2 small pieces of steel (A) that will act on the gland, but stay inside the inner diameter of the cylinder barrel. Then I whack gently at B.
Once the springy wire is freed up, how do you get it out? I am not able get a small screwdriver or any of my dental-style picking tools underneath the wire.
So, I drilled a little hole and pushed it out. Anyone else have a solution they have used?
And here is the cap and piston, disassembled. I used the rod like a dent-puller to pound them out.
A lot of the goo seems to be grease used in the last assembly.
Next, I remove the piston nut.
Since it takes at least 300 ft-lbs of torque, I stick a rod in the cross-tube, park the tractor on it, then use a long breaker bar.
Here is the gland.
Only the wiper (A) and the gland seal (B) needed replacement. The rub-ring (C) seems to be metal, made of plain bearing type material.
Kubota actually still sells a seal kit for this cylinder, but it is listed at $175, or about $200 with tax and shipping! Crazy.
So I just bought A and B, plus the piston seal for $25/cylinder from Hercules.
In my experience, getting the new gland seal in is very tough if you don't buy the Special Tool. 25mm rods are much more difficult than even 30mm rods.
I recommend this tool.
For the piston seal, I like to heat it and the piston in hot water before sliding it on. I then clamp it overnight with a hose clamp to assist in assembly.
For contrast, this is a cylinder rebuild on a modern cylinder. This one is off my Chinese 1-ton excavator. The rod was dinged in shipping, so the gland seal started leaking after about 50hr of use.
At the time this happened, I had a spare cylinder, so I swapped it out, putting the leaker on the shelf for later.
This one has a screw-on threaded piston, with its own seal underneath. That sure seems unnecessary.
Thread-locker was also used, so unscrewing the piston was difficult, requiring a giant adjustable wrench and cheater pipe. Prob needed 500ft-lbs.
Oh yeah, the best thing about the seal on my Xiniu excavator: the maker was kind enough to stamp the size right on the side, and I was able to buy one, plus a spare for less than $10, total cost, shipped from China.
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2019 JOHN DEERE 333G SKID STEER (A52709)
2019 JOHN DEERE...
LARGE CONCRETE MANHOLE (A58376)
LARGE CONCRETE...
2012 John Deere 6170R (A57148)
2012 John Deere...
UNUSED FUTURE DHC 60" PALLET FORKS (A58376)
UNUSED FUTURE DHC...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
