dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,544
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Attached are a few pics of my welding excursion today. I finally got it out and ran some beads with all the rod stock the guy gave me with the welder. Tried a variety of settings and conditions with 6011, 6013, 7014, and even a bit of 7018 that was still left in there. The 6011 seemed a bit harder than the others, but I really didn't see a ton of difference among them. I used an old trailer ramp between 2 sawhorses as my makeshift welding table. Worked OK. I tell ya, DC stick welding is worlds apart from AC. I almost never stuck an electrode to the work on DC, whereas on AC it was the nightmare I remember from the class. I'm quite sure we were using AC only in that class I took years ago.
The first pic is a number of beads I ran on a flat scrap of steel. 3 different types of rod in there, but you really can't much tell the difference. After that very quickly got too easy, I welded on a plate to make a T. The second photo is a few beads I ran on the vertical piece - in the "horizontal" position. They like to sag due to gravity and were not so good. 3rd and 4th are the fillet welds I did on the T. Again, not so good. That will take more practice... A lot of the spatter in the third photo was actually dripping from the horiz welds up above it.
Now I need to build something. I'm thinking about a frame to set my toolbox into and with a place to hold a chainsaw on the rear of the tractor...
