ready for snow
   / ready for snow #11
The decal is for the spring tension and just says jammed blade can return without warning. I put these factory decals on it so people who see it think its a factory product. Then when I say I built it they are in awe.
I bet they are!! I am. Nice work!
   / ready for snow
Your tractor with R4 tires may have difficulty pushing a blade that big. A set of chains would enhance performance significantly.
Hoping I won't need chains. Blacktop dislikes that. I do have ballast for rear 3pt arms. Put lines on tonight and works nicely
   / ready for snow #13
some where on TBN there was a thread about adding grooves to AG tread tires for better snow traction.
   / ready for snow
Thanks for the link about grooving the tires. May even have what is needed if I ask around work. I happen to work at a tire plant.
   / ready for snow #16
   / ready for snow #17
Cartod; How's that thing push? My dad a snow blower on a V-twin craftsman tractor it does fairly well but that's not the same as trying to 'push' show. It seems if you made piles with a smaller tractor like that your bound to have a smaller and smaller area everytime you plow unless you push them wayyyy back the first time.
   / ready for snow #18
That's one of the biggest reasons to use a blower rather than a blade. If you don't start right away pushing WAY back and over-estimating your total snowfall you can easily box yourself in. The problem is compounded by a smaller tractor but still applicable with a big one. Once it freezes solid you are pretty much stuck with it where it is.
   / ready for snow #19
It does very well, it's a heavy little tractor with rear wheel weights and chains. It won't push a 10' drift but it will move the snow quite easily.
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A52472)
2022 ALLIANCE...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
MQ POWER 25KW GENERATOR (A52472)
MQ POWER 25KW...
