Ready for winter ~ prep list
   / Ready for winter ~ prep list #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I thought it might be useful to start a list of things to do to get our tractors ready for the winter season, before its too late and things get overlooked by procrastination.
I'll start.
I just decided to check out my battery condition and found that even though I had coated the posts and cable ends with the red spray post conditioner there was significant corrosion on the post ends. (This might be due to the tractor having sat since July through to nearly Oct. with no use. Next time I might disconnect the battery before a long storage period...)
This can be a real problem with cold starting and starting in general on the Kioti tractor line.
So I removed the cables, ground first and + last. Then, wearing safety glasses, I used a baking soda solution to clean out every little bit of corrosion between the bolt and the clamp. I used a post brush and cleaned each post until it was bright new metal. I filled each hole to the split ring with water, (distilled is best), and cleaned the entire battery top surface carefully and reinstalled the caps.
I used the felt rings and installed black on neg and red on +. Then I coated the posts with copper anti-seize and put the cables back on, first + then neg. I then sprayed the posts and cable clamps with the red spray to seal out and deter further corrosion. Job done!
Next contributor please!:thumbsup:
   / Ready for winter ~ prep list #2
Bought some anti fuel gel and added it to the tank and extra cans.
   / Ready for winter ~ prep list #3
Installed block heater.
Hoping the gas station has switched to winter diesel, tank is at 1/2 and holding out to put winter blend in.
Richie Water Master 1200 Trough (A50774)
Richie Water...
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2019 Harley Davidson (A50324)
2019 Harley...
