Real estate General topic
   / Real estate General topic #651
The guy whose video I watched appeared to only be using a hose with a fire nozzle and no sprinklers. He also appeared to be using the 1" HF clear water pump that has a very fuel efficient 79cc engine and a 35 gallons per minute rate of flow rating.
If someone lives in a rural area that doesn't have much fire protection service, but they have a source of water, to me this suggests that having one of the gas water pumps and hoses needed could potentially save someone's house that might otherwise be lost.
   / Real estate General topic #652
That could work if you're sticking around to manage water usage and keep the thing fueled.
I had envisioned the case of someone setting up the rig and then evacuating, in which case they'd empty a 15,000 gallon pool in just 25 hours with five 2 GPM sprinklers. Of course, a gasoline or diesel powered generator is still going to be fuel capacity-limited.
The devil is in the details.
Those I know that had planned roof sprinklers used gravity feed.
Slow but steady, with large tanks up a hill or on a frame.
In a tight neighborhood, I guess an engine powered system, but yeah, logistics to keep it wet at the right time would be interesting.
   / Real estate General topic #653
The fact that some were able to save their homes by pumping water from their home pools with $400-500 of inexpensive equipment IMO disproves the excuse that nothing could have been done to save all the homes that were lost.
   / Real estate General topic #655
Expert testimony not required for matters of common knowledge.
   / Real estate General topic #656
You can't really make that statement. Conditions varied by neighborhood, one having access to power and water while another did not. Others found the line of fire approaching their home at a time of day or week when winds were at their worst, versus another facing that condition at a more favorable time with lower winds or those blowing in a favorable direction.
Weren't the winds blowing something like 40 - 60 mph one day? No one is fighting a wildfire back with DIY equipment, under those conditions.
There's also the simple fact that some are more mechanically capable than others. An engineer, plumber, or mechanic is going to have a better chance at saving their house than the average chiropractor, psychologist, or illustrator.
Surely some could have been saved that were lost. But "all the homes that were lost"? C'mon...
   / Real estate General topic #657
If they only had lot size and building rules to limit fire spread. But hey, developers win.
Many people in the less affluent neighborhoods don't have a pool, or money.
The LA area catches fire all the time, poor brush mgmt, houses too close together, houses built to be extremely good at burning, an area where fresh water is scarce, expensive and politically controlled.
The Santa Annas, for anyone who has not been in one, are like standing in front of a huge fan , except the air is hot. Add the wind turbulence caused by fire and you have one of the best ways to make a fire superhot and move fast. Using water is just pi$$ing in the wind.
Only way to stop a fire like this is by removing fuel, which is just not done in most of LA.
And your neighbors will rat you out if you try and remove brush and trees without a permit.
Ok, going off topic, but for many of these things, we end up back at Infrastructure. So many threads kinda go there. It's expensive, inconvenient, and takes years, and it's always easier to build new than rehab old...
I also want to point out a couple things;
1) we have fires, but they are different, so i don't want to comment too much on something I don't understand.
2) True scale of things is often Not what the news shows. Don't remember the Hurricane, but I was watching news showing a very identifiable house, and a very specific place, with wave tops appearing to hit the 3rd story window. Wow... must be awful. We'll, 45 minutes later, I'm at the same house, checking for erosion on the bank and shore boulders, 50 ft from that Samw house, and waves are spraying over seawall, but thats it. News had placed the camera low, to look up at the waves, and posse the pictures. Also, even some Really bad hurricanes, it seems to show Massive destruction, and reality is it's bad in a 5 mile swath, and beyond that maybe 10 miles, 1 in 3 homes have "damage", and go out 25 or 50 miles and it's 1 in 10, and 1 in 50. So, 10,000 structures is what I've heard about the fires. That Sucks for those people, but that's likely less than 0.6% of homes in LA.
Even numbers of "damaged" is often inflated. I donr consider gutter down spouts being blow off to be "damage". That doesn't relate completely to the Cali fires, but 10,000 structures doesn't mean 10,000 homes and or businesses. That might be 5,000 homes, 2,000 barns/aux buildings, and 3,000 phone booths. At the same time, 10,000 structures could include condo buildings, and potentially be more than 10,000 single family homes.
UNUSED JCT QUICK ATTACH DIGGER ARM (A51248)
UNUSED JCT QUICK...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
Adams 5T High Clearance Fertilizer Spreader (A53472)
Adams 5T High...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
BUSH HOG 7007 LOT IDENTIFIER 103 (A53084)
BUSH HOG 7007 LOT...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
