Really hard going from 2WD to 4WD
   / Really hard going from 2WD to 4WD #11
That should work!
Make sure you are pointing in a straight line.
Check your tire pressure. If pressure is off, my 25 year old B8200 will resist changing 4wd/2wd.
Lift the front wheels slightly of the ground using the loader and it should slip easily out of 4 wheel drive.
Vic
   / Really hard going from 2WD to 4WD #12
All the suggestions are excellent.I have also found the tire pressure on my tractor changes daily.When the differential is excess this changes the circumfrence,causing hard shifting.Something else you might consider,
   / Really hard going from 2WD to 4WD #13
My 'Bota manual suggests that if it's difficult to get it out, turn the front wheels left or right.... worked like a charm for me.
   / Really hard going from 2WD to 4WD #14
my manual tells me that if its hard to go from 4wd to 2wd back up a foot or two and then try. it has worked every time for me.
   / Really hard going from 2WD to 4WD #15
To have to back up, turn the wheels or pic the front end with a loader is a air pressure balance issue.
   / Really hard going from 2WD to 4WD #16
I fought with my L3400 in the early days but realized if I release the tension on the drive train it doesn't take much force to engage/disengage. Hills and hard surfaces are the toughest for me, since my technique has been to roll forward or back a few feet, a few times.
This sounds like great advice. Like, kick myself for not thinking of it advice:
Vic
There is probably no need to use much force and it's probably a bad idea to do it often.
   / Really hard going from 2WD to 4WD #17
I have had Kubota 4 wheel drive tractors since 1980. The first 2 were gear drive and this is a HST (B3200). I have found that the tractor will go in to and out of 4 wheel drive very easily if I am rolling on a level surface without pressure on the drive train. Start moving and let off on the forward HST as you push the lever in to or out of 4 wheel drive (do not depress the clutch). It falls in and out very easily. It will be difficult if there is any strain on the drive train.
I hope this helps.
Jim from NH
   / Really hard going from 2WD to 4WD #18
all good to know, I am not having any problems but if I start having issues I will have lots of things to try
   / Really hard going from 2WD to 4WD #19
I have a B7500 and it slips in and out smooth as butter, and I shift it often, the only thing i do is make sure i am moving straight ahead for about 5ft before I try shifting it, i never have any bind up.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
1267 (A50490)
1267 (A50490)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
1472 (A51247)
1472 (A51247)
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
