Rear Axle Seal Housing
   / Rear Axle Seal Housing #12
Is there enough bolt left sticking out to remove or are you going to have to drill and use an easy out?
Of the four one I might be able to come out with vise grips. The others will for certain need drill and easy out
   / Rear Axle Seal Housing #16
I take a dremel with a 3/4" cut off wheel and cut a slot in the bolt for a flat head screw driver on some bolts or use a good cobalt reverse drill bit. Be sure to center it and drill all the way thru to oil it from the back if it doesn't start turning.
Spray oil is your friend Id start spraying now then step up a size on the rev bit the next one may grab and turn. Then if all that fails use an easy out or drill it and re-tap or drill bigger and helicoil. hth
If I am the least bit afraid of breaking a bit or easy out I simply drill and tap then you aren't sol.
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2014 XL SPECIALIZED TRAILER XL 110 HDG RGN (A52472)
2014 XL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
1267 (A50490)
1267 (A50490)
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
