Rear Blade Rear Blade 1026r. Best bang for the buck?
   / Rear Blade 1026r. Best bang for the buck? #21
So do folks usually use the rear blade flipped around, to push snow in reverse? Seems like that could get old. I suppose it would be mixed benefit to drive forward with a rear blade to clear snow, since the tires would be compacting it.
With few exceptions, you pretty much have to push backwards with a rear blade. Otherwise the snow builds up very quickly between the blade and your rear tires and then what are you going to do with it?
   / Rear Blade 1026r. Best bang for the buck? #22
How about an alternative suggestion ? Save your money for a couple of years and then get a three point snow blower. That is what I did and I am very happy now. I can move the piles back and I don't end up with no where to put the snow towards the end of the year.
   / Rear Blade 1026r. Best bang for the buck? #23
I use the blade in reverse and it does a good job behind the x749. Last year I was able to clear about 18" in one event quickly, about 45 minutes and this would have taken several hours to do by hand. Like I said beats a shovel.
   / Rear Blade 1026r. Best bang for the buck? #24
I like to run the blade backwards of what you normally would for a small amount of snow, If you are going forward have the cutting edge facing backwards and do the opposite for going in reverse. The cutting edge will not dig up gravel that bad when you run it backwards.
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
