Rear blade angle cylinder bent rod
   / Rear blade angle cylinder bent rod #11
No a crossover wont work due to the fluid differences. Ignore the fact that there is a piston for a moment. You are shoving a 1-1/4" solid rod into a confined cylinder full of fluid. That HAS to displace fluid somewhere. If the valve is closed....there is no where for it to go....crossover or not. It has to EXIT the system....IE...bust a hose or bend/break something as seen.
Now a 3-1/2" cylinder would make a world of difference.
In my above math....assuming kingpin is 6" away and 8:1 mechanical advantage. The 3" cylinder allows you 2200# of force in compression and 1800# of force in extension at the edges of the blade with 2500psi.
Now a 3-1/2 would be about 3000# compression and 2500# in extension. So just going to 3.5" cylinder gives you almost 50% more ability before over-pressurizing the system.
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
