boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
some things to think about....
FEL (front end loader) with heavy duty bucket. would most likely be advisable. as bare min.
ya going to need counter weight in the rear end. either tires filled with a liquid, to a 3pt hitch implement that is heavy. to counter balance weight of FEL, and be able to really put the FEL to use in heavy conditions
TNT (Top N tilt) = 1 or 2 cylinders to adjust angle, and then another hyd cylinder for top link for 3pt hitch. you can get manufactured to 3rd party kits. to replace the old turn buckles / hand adjustment linkages on 3pt hitch.
TNT will either take 2 to 3 rear remotes, double check on what type of "valves" you want for these rear remotes.
on top of that you most likely want 2 more rear remotes for anything else that may come along that has another hyd cylinder or like on it.
with above 3 or 4 rear remotes should cover pretty much everything out there, exception the rare few 3pt hitch implements that require 5 rear remotes.
rear blade, box blade, or land plane (grader blade), or *duh* forget name york rake? looks like a old metal garden rake but 3pt hitch version. out of the 4, you most likely would want a min of any 2 of them.
box blades, normally have scraficer teeth on them. and normally have area on top, were you can place extra weight. to allow you to drop them teeth into the ground. to really rip up the ground. and then it makes everything else easier for rear blades, box blade leveling, land plane, etc...
4 in 1 bucket
heavy duty bucket with a tooth bar for it,
heavy duty bucket with grapple.
the 4 in 1 bucket, can turn into a dozer blade to some extent. it will be no were as maneuverable as a dozer blade but...
heavy duty bucket with tooth bar. if ya needing to do some digging with the FEL. the tooth bar helps cutting into dirt easier. though tooth bar can be a 3rd party add on.
grapple. if ya needing to remove brush and stack it in some central place to burn.
i might suggest a backhoe. if you are going to be one left to removing tree stumps. that or when ya need use of a backhoe, goto local machine rental place, and rent a mini excavator or excavator. and just go at it non stop for a couple days to do what ever projects you have saved up.
if you do go with backhoe 3pt hitch backhoe with sub frame, and will have a good amount of use, suggest getting a tractor created for a backhoe, were you turn seat 180 degrees and backhoe controls are there. vs getting off of tractor, and walk around to backhoe seat. (ya walk a couple miles)
if you have not already spend some time over at EverythingAttachments.com and watch videos of pretty much every implement listed on there website. in how to use them and set implements up.
what ya wanting, and what ya needing, is going to be a pretty high dollar. i hate to say it.
if you get the "high dollar ticket items", tractor itself, FEL, and what ever will fit into your budget for highest price implement you can afford. and then wait and save for the less expensive items. thought is pay big now and all at once and more likely get a larger discount. and then the cheaper implements. you might come across something used, or perhaps some sort of "sale" later on down the road. if you are patient enough for a given implement.
4 in 1 bucket
