Rear Blade
/ Rear Blade #1
hacleme
Bainbridge, Georgia
Mahindra 3616
I am currently shopping to purchase a 6 ft rear blade. I want a good quality that will last and have narrowed it down to a few.
I have a driveway in excess of 3/4 mile. Sandy based soil. I'm tired of using the box blade and feel a blade would do better, save me time and I just want one.
Brands and pricing quoted less taxes. All 6 ft with no accessories. Looked within a 90 mile radius of Bainbridge Ga. (Delivery extra)
Woods HBL72 for 1375.00
Land Pride RBT 3573 1502.00
Bush hog 70 series 1399.99
I do not mind driving to pick the blade up or pay shipping but would like to know are these prices in line? If anyone knows of better pricing let me know where please.
/ Rear Blade #2
I bought one of these recently. I fully recommend the company and the product. I will weld onto the cheaper model I have a retractable stand or support for when it is not on the 3-point hitch. More expensive model not worth the extra cost for my small tractor. e-mail me teeth4u@earthlink.net for any questions, or you can see it in Cataula, GA.
Watch their videos.
/ Rear Blade #4
Why is the box blade coming up short for driveway maintenance for you? I think if you're looking for a blade to do a "better" job, you're going to be disappointed. Since I got a box blade, I rarely use my straight blade for anything but snow.
BTW, I paid $329 new for the KK 72" blade... it's not as heavy duty as the others but for what you're looking for it sounds like it'd be WAY more than enough. If you're going to spend big money on a 6' blade I'd go with a hydraulic angle.
/ Rear Blade #5
IMO, the BEST implement to maintain a drive is one of these. Rear blades have their place just as box blades and landscape rakes do. But none of those compare to a grading scraper when it comes to maintenance. Trust me, I have them all. ;)
One last thing, if you get a rear blade, you will be happier with a 7 footer. I hope to get a Land Pride RBT3584 one of these days for my Mahindra 3215. :drool: Don't forget the skid shoes for whatever rear blade you get if you go that way. ;)
/ Rear Blade #6
I would go with the Woods HBL72. I was thinking they were around $1200. If it doesn't have to be quick hitch compatible look at a Monroe Tufline GB4-72. It is made similiar to the Woods HBL blades.
The Everything Attachments extreme duty blade would also be nice for your tractor. It is less $$$$ than the others.
Everything Attachments XTreme Duty 6 way Tractor Scrape Blade
/ Rear Blade #7
OMG, so expensive, why not directly buy from factory? now is 21 century, the century for internet business.
/ Rear Blade #8
One of the blades I have my eye on is the LandPride rbt3584 although it's alot more than your number. I like the idea of being able to easily add the hydraulic angle later (or more).
The heaviest ETA one looks okay, but I still think they could easily design it with mounting brackets for a possible cylinder as well. A friend has a home modified rear blade that does hydraulic angle and he strongly recommends at least that adjustment from the seat.
So for me the ETA is probably out of the running.
/ Rear Blade #9
I have a Land Pride RB 3596 rear blade. Its used mainly for snow plowing since I got the Land Pride GS 2584 (grading scraper). There is simply no comparison - the grading scraper does such a better job on the driveway. There is no way I can control the rear blade and produce the results the scraper gives.
/ Rear Blade #10
'Rhino" makes a very substantial and well engineered blade. Worth a look.
/ Rear Blade #11
I like the idea of those land plane kind of implements for making things flat, but I can you put a slight crown on a road with those?
/ Rear Blade #12
You can, as in it is possible, and it most likely depends on how long it would take with the type of material that you are working with. IMO it is best to maintain a road with a LPGS, but if you need to get that crown, it is best to use a rear blade. I shape my roads using my box blade and rear blade. Maintenance is done with the LPGS. ;)
/ Rear Blade
Thank you for the information and knowledge. I will order a LPGS. Would a 3616 pull a 7ft or should I stay with a 6ft?
/ Rear Blade #14
In my opinion, even a 6 footer may be to wide. Sort of depends on the ground that you will be using it on and how heavy your LPGS is. I have a 60" LPGS that I use behind my 3215 that is ballasted to 5000lbs. It weighs about 800lbs and at times is all the tractor wants. I have a 7 footer that I use behind my 7520 that is ballasted to 12,000lbs, the 7 foot LPGS weighs 1400lbs and if I don't pay attention, will stop that tractor dead in it's tracks.
Lots of variables, I would try to get an industrial or commercial grade 60" or 66" unit if you can find one. If not, a 6 footer that weighs 600-800lbs would probably be good. but a heavy 6 footer is going to be to much for your tractor IMO.
/ Rear Blade #15
I have a Tufline 7' rear blade that's worked well. It has ribs behind the blade to prevent crimping.
2018 DIAMOND T TRAILER 40 GOOSENECK (A60736)
2018 DIAMOND T...
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
1973 White Trucks Western Star Dump Truck (A61165)
1973 White Trucks...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
