Snow Equipment Owning/Operating Rear blade
   / Rear blade #1
garbageman
Orange County, NY
Kubota 7500
I know we have plenty of nice weather left but I was looking at my 7’rear blade which I use for light snow
I would like to add a “plastic “ cutting edge to the blade
I read past post but can’t seem to find a website to purchase the “plastic”
Can someone help out
Ray
   / Rear blade
“plastic “ is not the correct word. I believe it is a Poly Edge
Was not sure how to edit my post
Ray
   / Rear blade #3
You can use poly or even a thick piece of rubber..
   / Rear blade #4
   / Rear blade #5
We used the tread portion of an old tire at work on a rear blade. It was held in place by clamping it between the cutting edge and the moldboard. Lasts forever. The guys liked it for plowing over some of the irregular surfaces and for doing squeegee work on slush. The tire material was difficult to work with, but it still looks like new after several winters.
   / Rear blade #6
Same idea but horse mats is something I’ve read about too.
   / Rear blade #7
Some snow plow dealer offer ploy cutting edge.
   / Rear blade #8
I got horse stall mats on sale at TSC last year. $35 for a 4x6 1"thick.
On my truck plow, I used thick wall plastic pipe that I got free from scrap left over when they installed gas lines near me. Cut a slot, and ratchet strapped it to the blade. Once I got a base of packed ice/snow, I took the pipe off and could scrap with the metal edge. Nice to have both types of blade edges.
   / Rear blade #9
My strip of horse stall mat is holding up well after 2 years. I've got the rest of the mat if I need a replacement.
   / Rear blade #10
Before my driveway freezes rock hard - I simply reverse my rear blade 180 degrees to plow snow. Works great and doesn't gouge up the soft gravel.
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
1999 Toyota Camry Sedan (A50324)
1999 Toyota Camry...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
