Rear Discharge vs side discharge finish mowers?
   / Rear Discharge vs side discharge finish mowers? #1
Skaning
Gloucester Co, VA
Hinomoto E18D
A simple minded question from a relative newbie at this. What, if any, advantages are there between side discharge mower and rear discharge? The safety issues of flinging debris out the side vs a chain guard in the rear is obvious enough. What I'm curious about is there any benefit in cut quality or operation between the two?
Skaning
   / Rear Discharge vs side discharge finish mowers? #2
I really don't think there is much difference between the actual cut. Both are about the same. The rear discharge if on a MMM tends to plug a bit more and leave clogs. The side discharge does a better job of getting rid of your clippings. But if you mow religiously you won't have any trouble. The rear discharge is nicer because you can trim from both sides. Now my comments are based on MMM not 3 point mowers.
murph
   / Rear Discharge vs side discharge finish mowers? #3
From a person who uses a 3-point RFM, the rear discharge mower puts the discharge so far behind you, and discharging back away from you, I can cut 2-1/2 acres and not even get in to the dust and dirt that happens with a side discharge that always seems to get blown back at you....
Todd
   / Rear Discharge vs side discharge finish mowers? #4
I investigated this before buying my rfm. By and large, side discharge mowers have a smaller discharge opening and so tend to clog more readily. Also, as Murph pointed out, with side discharge you have to mow in one direction to avoid continually mowing over the discharge. This isn't the case with rear discharge where you can mow in any direction that takes your fancy.
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
