Rear Discharge vs side discharge finish mowers?
   / Rear Discharge vs side discharge finish mowers? #1
Skaning
Gloucester Co, VA
Hinomoto E18D
A simple minded question from a relative newbie at this. What, if any, advantages are there between side discharge mower and rear discharge? The safety issues of flinging debris out the side vs a chain guard in the rear is obvious enough. What I'm curious about is there any benefit in cut quality or operation between the two?
Skaning
   / Rear Discharge vs side discharge finish mowers? #2
I really don't think there is much difference between the actual cut. Both are about the same. The rear discharge if on a MMM tends to plug a bit more and leave clogs. The side discharge does a better job of getting rid of your clippings. But if you mow religiously you won't have any trouble. The rear discharge is nicer because you can trim from both sides. Now my comments are based on MMM not 3 point mowers.
murph
   / Rear Discharge vs side discharge finish mowers? #3
From a person who uses a 3-point RFM, the rear discharge mower puts the discharge so far behind you, and discharging back away from you, I can cut 2-1/2 acres and not even get in to the dust and dirt that happens with a side discharge that always seems to get blown back at you....
Todd
   / Rear Discharge vs side discharge finish mowers? #4
I investigated this before buying my rfm. By and large, side discharge mowers have a smaller discharge opening and so tend to clog more readily. Also, as Murph pointed out, with side discharge you have to mow in one direction to avoid continually mowing over the discharge. This isn't the case with rear discharge where you can mow in any direction that takes your fancy.
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2020 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A54607)
2020 VOLVO...
