Rear fender spash guards
   / Rear fender spash guards #11
Riding a Deere is like riding a Harley.....cost wise I mean:p
   / Rear fender spash guards #12
You can make front fenders out of a 'black' 55-gallon plastic drum.
Just cut out your length & width you want.
   / Rear fender spash guards #13
The compatibilty with the MMM may be with the new auto connect deck. Looks like the bottom of the guard might hit the front of the deck while driving over it.
$250 for two small strips of plastic for the rear is crazy. I know Deere has to make money but that is just nuts!
I suspect you are right about the non-compatibility with the newer auto connect deck. My mmm is the older 7 Iron 72" deck.
I bought the rear fender extensions and front fender/mud guards when purchasing the tractor new so I got about 17.5 % off with the package but that is still way too much.
   / Rear fender spash guards #14
Front fender kit (3000 TWENTY Series)
Front fender kit
Front fender kit
The front fender kit provides protection to cab glass or the operator station from mud and debris. This kit contains two fenders, mounting brackets, and mounting hardware.
Compatible with cab and open-station models.
Code Bundle Description
LVB25686 Front fender kit (3000 TWENTY Series)
Note: Not compatible with mid-mount mower.
Last Updated : 10-Aug-2009
Hmmm, JD states the kit is not compatible with MMM. I have the front fenders on my 2007 JD 3720 cab tractor with MMM and have no problems whatsoever. Maybe they changed design since then.
They state the same in the manuals about the Turf Specials and I have been running them without issue and any rubbing on the MMM.
   / Rear fender spash guards #15
No kidding and then either purchase the JD brackets or fabricate your own.
Thanks guys I didnt even think about the rubber fender guards for a pu or jeep that would work and not cost anywhere close to what JD wants for them. I was only wanting the rear guards but thanks for the imfo on the front fenders. They would work fine for me I only have a rear finish mower not a mid mount. ILMOMAN
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
