Rear finish mower 72 inch
   / Rear finish mower 72 inch #11
Never used anything but the side discharge in a finish mower but we're satisfied with it. Can't make a comparison between the two though, sorry.
   / Rear finish mower 72 inch #12
I went with a rear discharge and so far it does distribute the cut grass perfectly but the main reason was that my trailer is 76 inches between the rails so it fits on the trailer with a few inches to spare. It's hums along real quiet and smooth..........rc
   / Rear finish mower 72 inch #15
I've got a 72" KK rear discharge. The reason I went with the rear was the discharge area is a lot bigger. If the grass gets a little taller than it should before iI get it mowed it doesn't leave a windrow of grass. Also if you hit a rock or some other hiden object. it goes out the rear not out the side to bounce off the truck or the siding on the garage.
   / Rear finish mower 72 inch #16
   / Rear finish mower 72 inch #17
This past weekend I picked up a '99 RFM72. Haven't had a chance to use it yet. It's in good shape overall. The PO wasn't very good with his tractor, so the 3pt. hookup was bent on one side, and both side shields were badly bent up. I'm working on straightening everything now and greasing things up. I wondered if anyone had tryed to turn it into a mulcher by blocking off the side discharge. Mine is missing the shield anyway, and I was just going to make a cover for it. I don't think it would be too bad as long as the grass wasn't too long. Any opinions?
   / Rear finish mower 72 inch #18
   / Rear finish mower 72 inch #19
I have a bush hog 72 rear discharge. What amachine I love it. KK sells a mulching kit for most of their large cutters. Check one of these out before buying new blades or other stuff to convert to a mulcher.
   / Rear finish mower 72 inch #20
2005 TerraGator 8104 (A52748)
2005 TerraGator...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
