Rear Hydraulic 3 pt Operation
   / Rear Hydraulic 3 pt Operation #1
sld
Veteran Member
Midwest
Ford 1210 / Ford 1710
Hi all,
I just did a lot of maintenance on my Ford 1210 4WD. It had sat for awhile so I changed all fluids and filters.
I never noticed this before, but when I raise the 3 pt, it comes up a little jerky. It's not real bad but not as smooth as going down. The only implement I have put on is the rear blade as I am getting ready for moving snow. It was still slightly jerky coming up.
Is this normal? Is there something I should check?
Thanks for the help.
   / Rear Hydraulic 3 pt Operation #2
It should not be jerky. I wounder if you have air traped in the tph cyl. I am assumeing you changed the hyd fluid and filter. Try lowering the arms all the way down and this might push the air out. Keep raising and lowering the tph to try to work the air out.
Bill
I did change the filter.
I will try raising and lowering it several times to see if it smooths out.
There really is no way or need to bleed a system like this is there?
   / Rear Hydraulic 3 pt Operation #4
I agree that there is probably air in the system. They are "self-bleeding" so the only way to do it is to cycle all the controls. Also make sure the filter is not loose and sucking air around the seal.
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
