Rear hydraulics on a 2520
   / Rear hydraulics on a 2520 #1
Mike5252
Cleveland, Ohio
JD 2320
My 2520 does not currently have rear hydraulics. I am considering purchasing an attachment for the 3pt hitch that would require hydraulic connections (chute control on a snow blower).
How major of an undertaking is it to add rear hydraulics to a 2520? Is this something that I should be able to do myself? About how much would it cost to have a dealer add these?
Assuming I want to leave my FEL on, how would I control these rear hydraulics?
   / Rear hydraulics on a 2520 #2
Mike , i am fixing to do the same thing.
Look in the hydraulic forum. there is a few people that have added hydraulics to the 2520..;) alot of good info.
also do a search on KennyD's posts. he shows a step by step how to do it. when he did his.
Chris..:)
   / Rear hydraulics on a 2520 #3
Mike, I had the dealer add rear hydraulic to my 2520 to operate the hydraulic cylinder on my trailer. The only problem is I have to disconnect a couple of the hoses to the loader. The rear hydraulics ia an option that can be added, although mine looks like an after thought. Cost was about $150.
   / Rear hydraulics on a 2520 #4
Do you have Power Beyond? If so, you should be able to adapt a hydraulic valve to it. The hardest part seems to be matching the quickconnects, but you should be able to add a single spool valve for ~$100-150 (probably less if you, unlike me, know what you're doing).
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
Year: 2000 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 120,822 Plate: Body Type: 4 (A55852)
Year: 2000 Make...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2022 ELECTRIC MINI SKID (A55745)
2022 ELECTRIC MINI...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
