Rear hydraulics on a 2520
   / Rear hydraulics on a 2520 #1
Mike5252
Cleveland, Ohio
JD 2320
My 2520 does not currently have rear hydraulics. I am considering purchasing an attachment for the 3pt hitch that would require hydraulic connections (chute control on a snow blower).
How major of an undertaking is it to add rear hydraulics to a 2520? Is this something that I should be able to do myself? About how much would it cost to have a dealer add these?
Assuming I want to leave my FEL on, how would I control these rear hydraulics?
Thanks
   / Rear hydraulics on a 2520 #2
Mike , i am fixing to do the same thing.
Look in the hydraulic forum. there is a few people that have added hydraulics to the 2520..;) alot of good info.
also do a search on KennyD's posts. he shows a step by step how to do it. when he did his.
Chris..:)
   / Rear hydraulics on a 2520 #3
Mike, I had the dealer add rear hydraulic to my 2520 to operate the hydraulic cylinder on my trailer. The only problem is I have to disconnect a couple of the hoses to the loader. The rear hydraulics ia an option that can be added, although mine looks like an after thought. Cost was about $150.
   / Rear hydraulics on a 2520 #4
Do you have Power Beyond? If so, you should be able to adapt a hydraulic valve to it. The hardest part seems to be matching the quickconnects, but you should be able to add a single spool valve for ~$100-150 (probably less if you, unlike me, know what you're doing).
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
Teakwood Dining Table (A55758)
Teakwood Dining...
Giyi Log splitter (A53316)
Giyi Log splitter...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
6' 3pt. Cultipacker (A50775)
6' 3pt...
