DaveK OR
One issue has come up with regard to the hydraulics for my Woods backhoe. That is, should I use the rear hydraulic A-B ports, or go to the trouble of tapping into the power-beyond and plumbing a separate return.
In reading the instructions for the Bobcat (Rhino-built) backhoe, Bobcat recommended (requires?) using the rear hydraulic A-B ports. On the other hand, Woods recommends separate, dedicated supply and return lines. I installed the rear hydraulic kit specifically because I eventually wanted to add the backhoe, so it will be very frustrating to have to add additional plumbing at this point.
So, a few questions:
1) If I use the A-B ports, I can see a potential for having reverse flow to the backhoe hydraulics. This would occur either by reversing the supply lines, or putting the A-B control lever in the wrong position. I understand that the backhoe would not operate with reverse flow, but would such a mistake actually damage the backhoe hydraulics?
2) Does the A-B control valve operate with an "open return" on either line? That is, whichever line is being supplied with pressure, the other provides no significant resistance to the return flow. Also, when the A-B lever is in the "neutral" position, do both lines provide that open return?
3) Is there a difference between the Woods and Bobcat backhoe hydraulic controls, such that it makes a difference in how hydraulic flow is supplied to the backhoe?
4) Anything else I should consider about my hydraulic hookup decision?
