Rear Hydraulics project of my very own.
   / Rear Hydraulics project of my very own.
Yes sir, The original return line on there from the loader side has that big 90 degree bend that makes changing the orientation a bit of a problem as well.
   / Rear Hydraulics project of my very own. #12
Looks good, hope it works out well!
I think you would save some space if you could rotate the T, but you'd need to get a new hose (or have a new end put on if long enough). Or add a hose and move the T elsewhere. Building a guard was probably the quickest/cheapest solution.
   / Rear Hydraulics project of my very own. #13
Mine does not T at all, I removed the green line or power beyond. I will try to figure out how to post pictures. I can leave the hitch on mine with the woods.
   / Rear Hydraulics project of my very own. #14
Very nice job. :thumbsup:
Maybe you can find a T that you can put on the other way so the T'ed joint is on the tractor return. Now the top of the T runs parallel to the tractor. Put your rear return from the new valve on the back like you have now and rotate the loader return line CCW 90 degrees so it will go on the front of the T.
gg
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2010 BIG TEX 16 T/A TRASH TRAILER (A55745)
2010 BIG TEX 16...
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
1000000 (A47477)
1000000 (A47477)
SHOP CART W/CONTENTS (A55745)
SHOP CART...
