Rear lines
   / Rear lines #11
Two lines are required to run a BH. I don't understand the purpose of a third line. Doesn't the kit have instructions or labels?
I'd also suggest posting a question in the Mahindra forum. Those guys don't necessarily check the hydraulic subforum
   / Rear lines #12
I am fairly sure that most of the manufacturers have gone to the 3 line system on their hoes. The 3rd line is a return to tank line.
   / Rear lines #13
I have 3 on mine.
   / Rear lines #14
I am not familiar with your tractor and the BH; but, here goes some thoughts. Most newer tractors use an open center power beyond system. Power (P), Power Beyond (PB), and Tank Return (T), three hoses. Unless the BH is also PB equipped that is a separate problem. You can use the PB connection on the tractor to the P on the BH; but, anything down stream from the PB (FEL, 3 point, power steering are some possibles) on the tractor will not work when the BH is connected. another thing to check out on the hydraulic systems of each
   / Rear lines #15
My BH runs off rear remotes and only has only two hoses. I guess if power beyond circuit is used there is an additional hose.
I still don't understand how a tractor dealer could not sort this out.
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
FAKE (A52472)
FAKE (A52472)
TUBELINE TL50LSV LOT NUMBER 119 (A53084)
TUBELINE TL50LSV...
