Rear mount finish mower belt replacement
   / Rear mount finish mower belt replacement #1
coolbrze
VA
Kubota MX5800
Is there any special way to mount the belts on my Befco C50 (60") rear mount finish mower? Can I just stretch it around the pulleys or is there a better way to putting it on?
   / Rear mount finish mower belt replacement #2
One or more of the pulleys should have a bolt adjustment or a sring tension set-up. I'm not familiar with a Befco, but most I have seen have the spring tension set-up.
   / Rear mount finish mower belt replacement #3
The process is described in your manual. If you don't have a manual, I suggest you contact Befco. The C50 mower is in current production, so you shouldn't have any problem getting a manual.
Before you replace the belt, ensure the tensioner (the pulley that is connected to a spring) cannot be adjusted. On the C30 mower, the tensioner has three positions to accommodate stretching.. Belt deflection halfway between the drive and side pulleys should be ~3/8th's inch.
On the C30 (that's the model I own), the manual states to start installing the belt on the right pulley. I don't think it really matters as long as you have the belt seated in all the pulleys.
Just make sure the belt tensioner is in the first (tightest) hole when you're done.
Thanks for the help. I'm picking up the belt this a.m. What does the spring or bolt tensioner look like? I can't find my manual at the moment so I really appreciate the help guys.
   / Rear mount finish mower belt replacement #6
"What does the spring or bolt tensioner look like?"
It's a pulley attached to a bracket that can pivot. The spring is attached to the bracket.
You'll really want to dig out your manual. The belt replacement is pretty simple, but you do need to remove some bolts from the center cover.
   / Rear mount finish mower belt replacement #7
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
Steiner VA242 Post Hole Digger (A50774)
Steiner VA242 Post...
