rear mounted "scoop"
/ rear mounted "scoop" #1
Anonymous Poster
Epic Contributor
rear mounted \"scoop\"
Hi, I'm looking at a rear mounted "scoop". I don't know what else to call it. It's used to move moderate amounts of dirt and mounts to the three point hitch of a tractor. I have a use for this implement and it is in new condition. The seller has no use for it and has offered it to me for $50. Is this a good deal? Should I jump on it? HELP! Thanks
/ rear mounted "scoop" #2
Re: rear mounted \"scoop\"
Is it a good deal? Are you kidding? You say it's in new condition? My old Tractor Supply Co. catalog has new ones for $199.
Bird
/ rear mounted "scoop" #3
I've seen a bunch of different models varying hugely in quality, but none of them were close to $50. So if it would be useful to you, buy it!
/ rear mounted "scoop" #4
ditto what mark and bird said!!!
/ rear mounted "scoop" #5
If it's not totally thrashed, for $50 it is well worth it. They range from $200-300 new.
They are handy; I had one before I got my front loader. Sold it a year ago to a friend with a Ford 8N. He used it a lot til he got his B2150 with loader.
RobertN in Shingle Springs Calif
Thanks for the info... it is in perfect shape and seems to be well built. I'm gonna run over there today and pick it up.
/ rear mounted "scoop" #7
NO NO NO do not buy it!!!!!
send me the name and number of the guy selling it so I can pick it up for $50! /w3tcompact/icons/smile.gif
/ rear mounted "scoop" #8
I'll give $60.00 for it- just so I could resell it for $120.00-- not bad for an hours work in my neck of the woods
Or I might just keep it to play with awhile before I resold it.
/ rear mounted "scoop" #9
L.,
I own a King Kutter rear scoop, I bought it used and it had been used a couple of times and I paid $100 and still believe that I got a good deal. I have gotten all of my money's worth out of it in one season. It's great for moving lots of things. You shouldn't be sorry for buying it. It is referred to as the poor man's front end loader and you should be able to dump it from your seat. Good Luck with your new toy...I mean productive piece of machinery!/w3tcompact/icons/smile.gif JimBinMI
/ rear mounted "scoop" #10
The scoops are good for all sorts of stuff. For 50 I would buy it right away.
Roddy
/ rear mounted "scoop" #11
Buy it! I just bought one for $250. One of the handiest things you can have if you don't have a front end loader. You can do a lot of moving and dumping material. I plan to keep mine even after I buy a loader to fill and use as a ballast box for rear weight.
/ rear mounted "scoop" #12
Re: rear mounted "scoop"
Very handy implement. A steal for $50. I have used one on my B2150 for years. Its a King Kutter from Quality Farm and Fleet, $200 about 12 years ago.
/ rear mounted "scoop" #13
I bought a Howse scoop for $220 and it lasted one weekend before the frame bent and I took it back. Got a King Kutter scoop for $320 and it has been great. I would not give you 50 cents for the Howse scoop but I am very well pleased with the KK. Be reasonably gentle when using the scoop and it will do fine. They will not take the pushing and pulling force that a boxblade will so don't try and move a mountain at one time with it.
/ rear mounted "scoop" #14
I think those things are more usefull than a front loader on a 2wd tractor. Unlike the front loader, which takes away traction as you fill it, you gain traction as you fill the rear scoop. The only problem with them is the limitation in lift height. I was able to overcome that handicap and use mine for loading manure spreaders, trailers, and pickup trucks by attaching a lift boom to the top link position and extending the lower links with a couple lengths of angle iron. This setup worked suprisingly well, not as good as a 4wd with a front loader, but close enough to get the job done.
/ rear mounted "scoop" #15
You guys have some valuable things to post about scoops and I agree with you about the usefulness--I built one for myself, BUT you ought to start a new thread abut your "Scoop experiences." Or something like Rob's thread about "How do you use your boxblade?" Your title could be "How you use your scoop?" I think that would generate some interest. There is no need to resurrect a thread from 2000!!:eek:
wolc123, Your use sounds interesting and a picture of your mod in use would be a valuable contribution. Have fun with your scoops!!
Mike
/ rear mounted "scoop" #16
As far as i'm concerned, buy it and fast, clue the wife in later. I've got a KingKutter I bought new , paid more than 50$ for it but wouldn't part with it for no money.!
/ rear mounted "scoop" #17
04-12-2000 11:54 PM - Anybody check out when this was (first) posted?
Almost 8 years ago... :D
/ rear mounted "scoop" #18
I gave the scoop away when I bought a 4wd tractor with a front loader a few years ago. I certainly got my moneys worth out if it while I had it. I even used it to dig a 1/4 acre pond (took quite a while but got it done). The lift attachment was very simple, and took me less than (2) hrs to make. This is how I did it: Place the scoop on level ground. Hitch a 3 pt lift boom to the tractor (available at TSC). Back up to the scoop and attach the boom through the end hook to the top link position of the scoop. Measure the distance from the lower links of the boom to the lower links of the scoop and cut a couple pieces of 3" x 1/4", or heavier angle iron 4 inches or so longer than this dimension and drill a couple holes in each to slide over the pins and make the connections. You may have to install longer pins on the implements to make room for the angle extenders. You will also want to have stabilizer bars on your tractor's lower links. Attach a long rope to the scoop release mechanism, loop it up over the frame and bring it to your tractor's roll bar. That is all there is to it, cut (2) pieces of angle to the right length and drill (4) holes. You need to have a tractor with fairly good hydraulic lift capacity to make this work. My old Ford 8n could just barely lift the empty scoop but my Ford 2000 would easily lift a heaping scoop of any material. I did have a couple suitcase weights up front to add stability. With a little practice, I got real good with this contraption and could load a manure spreader quite fast. I even used it to load dump trucks with topsoil, although I had to back the truck's rear axle into a ditch to get enough height. I have to say that it worked better than most 2wds with front loaders I have operated because of the vastly improved traction situation, although sometimes you would get a stiff neck from looking backwards so much.
/ rear mounted "scoop" #19
I want a KK 30" scoop, Sooo bad, just no money right now. Go get that thing before the guy has a chance to back out. Post some pictures so we can see what you got. bjr
/ rear mounted "scoop" #20
I guess it does not matter to them.:rolleyes:
Mike
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
New/Unused Wolverine 78in Land Leveler (A61166)
New/Unused...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
2003 Chevrolet 2500 Savana Van (A63116)
2003 Chevrolet...
