Rear PTO engages normally then disengages after less than a minute.
   / Rear PTO engages normally then disengages after less than a minute.
Answers to the many helpful questions:
Yes, I can shut off the PTO before it quits.
The mid PTO acts the same as the rear PTO.
If I shut off the PTO before it quits, the light extinguishes.
It acts the same without a load - I removed the rear attachment and observed the shaft.
I will offer another tidbit that I hope is not a wild goose chase. In the past, I was able to use the rotary cutter in forward and reverse without pulling out the PTO switch further. While I thought that was quite nice, it MAY be related to this problem.
   / Rear PTO engages normally then disengages after less than a minute. #12
If it has been bypassed, check the jumper wire for connection.
Thank you, Nikkorott.
With the rear attachment disconnected, the shaft acts the same as if there were a load on it.
   / Rear PTO engages normally then disengages after less than a minute. #14
On my tractor if I go into reverse with the PTO engaged the engine shuts down. I don't know if that's for people safety or equipment safety.
I'm guessing that you have a switch somewhere that isn't getting satisfied. Are your RPM's up when you engage the PTO?
SUCCESS!
Many thanks to those who took the time to contribute suggestions. The internet isn't all bad. Just mostly.
Executive Summary: The Reverse Switch was out of adjustment. Adjusting it solved the problem. The PTO (and the rotary cutter attached to it) works as advertised, in forward and reverse. The Reverse Switch is one of the inputs to the A1 Control Module (and who knows how that epoxied black box works?).
Mysteries:
1. Since the rear PTO can operate when the tractor is in reverse, why would the Reverse Switch cause a failure?
2. What the heck is with the 20-30 second delay before it disengages?
Details and kudos:
The Reverse Switch is on the starboard side, very well buried under the seat (which should be removed) and the plastic covers (that should be removed). They are easy to remove -- some push-fasteners and 10mm bolts.
Under the tractor, follow the linkage from the reverse pedal and you will find a plunger-type switch on the starboard side that SHOULD be depressed when the reverse pedal is in the relaxed position. As the reverse pedal is pressed, the plunger is allowed to extend. In this case, when it was not working properly, the plunger was not compressed with the pedal relaxed. Adjusting the switch solved the problem. To do so, however required exposing the switch adjustment (oh, yes and blowing out all of the grass and dirt that had piled up on everything from when it worked normally) and even then, it was tight quarters. There are two bolts that hold the adjustment plate to the . . . transmission? . . . They must be loosened first. Then the switch adjustment bolt needed to be screwed in and thus the switch moved closer to the reverse-pedal linkage until the Reverse Switch is normally depressed, and when the reverse pedal is pressed, the plunger on the switch relaxes and presumably the circuit is open. After that, be sure you tighten the bolts holding the plate to the . . . transmission.
Bottom line - many thanks for those who took the time to help, particularly those who took the time to dive into the system and provide specific guidance. As partial thanks, I hope this post will deliver a quick(er) fix to the next victim. Not counting my time, the fix was FREE.
Long live Right To Repair. We live in the sticks. It's pretty important that we be able to fix our equipment.
Sorry about the photo quality. As I said, it's in tight quarters.
The photos show an adjustment bolt that strikes a plate that moves the reverse switch assembly.
   / Rear PTO engages normally then disengages after less than a minute. #16
^^Great write-up on what caused your problem and good job figuring it out! (y)
   / Rear PTO engages normally then disengages after less than a minute. #17
Well done!
   / Rear PTO engages normally then disengages after less than a minute. #18
Pics would not post up. Usually easy to post pics on TBN, so no suggestion.
Glad you found the problem.
Thank y’all for the thanks.
I’ve uploaded the photos using the TBN attach link. The previous (failed photo upload) effort was pasting the text and photos from a parallel forum thread on Green Tractor Talk on account of my tractor being Green (John Deere).
202476 (A54757)
202476 (A54757)
2018 KENWORTH T880 DAYCAB (A55745)
2018 KENWORTH T880...
FAKE (A52472)
FAKE (A52472)
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
TANK MANIFOLD (A55745)
