Rear remote options for the T273
   / Rear remote options for the T273 #1
myyaz33
Platinum Member
Nebraska
TYM T273
Probably would get a better response in the Hydraulics forum, but wanted to see what options I have to get more rear remotes on my T273. Any add them on theirs?
   / Rear remote options for the T273 #2
Just curious...what are you looking to do that you need 2 sets of remotes back there? Anything interesting?
Only dreams at this point, but TOP-n-TILT with box blade that has hydraulic rippers.
   / Rear remote options for the T273 #4
That sound like a lot of fun!
   / Rear remote options for the T273 #5
I haven't done this Marty, and I'm just sorta wondering out loud .... but why couldn't a person just build two manifolds (basicly just T's), one with two male and one female disconnect, and another with one male and two female disconnects, that plugs into each of the existing rear disconnects, and go with that when needed?
If they turned out to be on the bulky side, it might be good to brace them so vibrations doesn't cause an issue.
Sounds simple to me, but I am a hydraulic dummy. Anyone else have any thougts on Flyer91's idea?
   / Rear remote options for the T273 #7
the reason to have dual remotes is to be able to INDEPENDENTLY control the two circuts, the scenario described would have two circuits that are dependent, in other words, they both do the same thing at the same time, and if one is easier to move than the other it will move more.
however if you have power beyond (such as to run a BH) you could install a control block and run remotes from that.
Aaron Z
   / Rear remote options for the T273 #8
You will probally want both spools side by side for easy reach and control. You can Posiblly mount a new Dual spool valve on the rops so and to keep it simple run 2 short hoses to the existing single remote who's control is in front of the seat , Leave it in the constant flow position and that should be it
would it running in constant flow (one way?) work?
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
