rear remotes kubota L4310
   / rear remotes kubota L4310 #1
rayclar
prince township , ontario, canada
kubota 4310hstc
Noob here, i was in tsc looking at quick couplers for my 4310 rear remotes and im stuck. i see pioneer standard coupler, poppit coupler?? What kind does mine take, they are a break away connection. Any help would be much appreciated. thanks ray
   / rear remotes kubota L4310 #2
Remove one of the QD's on your tractor and take it with you when shopping.
Hi j j, pulled the rear remote and the only # on the qr was sg parker bruning 9006-001. Does that tell you anything? ray
   / rear remotes kubota L4310 #6
Are you looking to get complete sets as in male and female ends? Are your current remotes OEM from JD? Most OEM rear remotes used on AG type tractors under 100HP are 1/2" AG fittings. If you are just looking for the male end, then more than likely you need a 1/2" male AG quick disconnect fitting. Should only be 6-7 dollars.
Hi mtn i have a oem remotes on a kubota, break away release, just not sure if there is a difference between break away and standard release male ends? thanks any info is appreciated.
   / rear remotes kubota L4310 #8
The std 1/2" male AG ends will be fine. The breakaway part has to do with the female end. ;)
2025 SDLANCH TRAILED CRUSHER (A58216)
2025 SDLANCH...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
METAL FLIP TOP 9 DRAWER TOOL BOX (A58374)
METAL FLIP TOP 9...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
