Rear Remotes
   / Rear Remotes #11
I only see 3 lines coming out of the control valve. Where are the other 2 lines coming from? I would guess you have a single acting 3 spool control valve which was used for a batwing. The MF tractor has a double acting 2 spool control valve. You might need to buy a new control valve to operate the stump grinder.
I agree, valve looks like it's for three single acting cylinders.
Could the other two couplers be from some way to reroute the three point hydraulics?
We need a trace of where the five rear coupler hoses go. List top to bottom, first the left side then the right side.
   / Rear Remotes #12
This is just a guess and is based on what I'm planning on doing to my tractor. The 2 lines on the right could be from a control valve to control a double acting cylinder. The 3 on the left could be to hook up an external control valve (Press, Ret, and Pwr beyond). But if it is then the Press and PB lines would have to connect when not in use to get pressure to down stream items. Just a guess, would have to see more pics of were each hose runs to get a better idea
   / Rear Remotes
I have determined at your suggestions that the remote was designed for power up and gravity down, the grinder has two way cylinders power up power down.
I have decided to remove the new working remote off tractor A and move it to tractor B which has a 40 year old controller that was leaking.
I will keep you posted on the results my darling wife is chasing down some reducers at this moment.
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2018 INTERNATIONAL LT625 DAYCAB TRUCK (A53843)
2018 INTERNATIONAL...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
