Rear Scoop -> Rock Scoop
   / Rear Scoop -> Rock Scoop #1
n6ckv
Penryn, CA
Kubota L3450
I initially got a rear scoop for my Kubota, but after getting a FEL I no longer used the rear scoop.
I have been following the ideas on rock removal, I have rocks from fist size on up. After I till I use a rake to windrow the rocks, but I had no good way to seperate the dirt from thre rocks in the windrows.
So back to the rear scoop, I cut out the bottom leaving a 2" flange around the hole. I have welded some re-bar in rows about 1 1/2 inches apart. Hopefully this will work as a rock scoop. When I get a chance to use it later this summer I will let the group know how well it works.
carl
   / Rear Scoop -> Rock Scoop #2
I'll look forward to hearing how it works and a picture or two.
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2014 FORD F-550 ROUSTABOUT(INOPERABLE) (A52472)
2014 FORD F-550...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
