Rear wheel offset from shaft - Good or bad?
   / Rear wheel offset from shaft - Good or bad? #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I saw some tractors from a new line and the rear wheels are offset from the shaft. Obviously the final gearing is done there. What are the advantages/disadvantages of doing that?
   / Rear wheel offset from shaft - Good or bad? #2
Don't know what line you are refering to and you did not say which direction the off set was. But there were a lot of "high crop" tractors built with the axle offset above the centerline of the wheels to get greater clearance for cultivating tall crops.
Metal Rooster Statue (A55758)
Metal Rooster...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
Fence Post Puller (A53316)
Fence Post Puller...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
Brock 5 Ton Feed/Grain Tank (A55301)
Brock 5 Ton...
2017 Ford Transit Connect Passenger Van (A55788)
2017 Ford Transit...
