Rear Wheel Spacers for wider stance?
   / Rear Wheel Spacers for wider stance? #1
MiserableOldFart
Platinum Member
Delaware County Catskills NY
NH Workmaster 40, Kubota GR2120
I've seen online a dealer that sells spacers for some select John Deere and Kubota models, but none for CNH. Is there such an animal? I would feel a whole lot safer if my wheels were two or four inches more apart, and the extra clearance for chains would be a blessing as well. I've seen some posts in the past about this, but I wonder if there is anything new out there..
It's not the hills, really. Steep hills you can avoid, but it's the little dips and rises in the ground, the uneven terrain that make the narrow stance of the CUTs a bit of a problem around here..
   / Rear Wheel Spacers for wider stance? #2
I've used the forged "adapter" style spacers on trucks and they work very well but they ain't cheap.;)
Thanks, but yes, they are dished in. I don't think they would fit on the tractor the other way.. The only way to get a wider stance would be with spacers of some kind.
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A59575)
2007 TEREX ADVANCE...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
1000 Poly Tank (A57149)
1000 Poly Tank...
